07-12-2020
11:12
10:13
JuanJoFitbit
07-12-2020
11:12
10:13
JuanJoFitbit
I lost my fit, how can i find it.
Best Answer07-12-2020 11:41
07-12-2020 11:41
If the battery didn't die, there are apps that will help you locate nearby bluetooth devices if you have an idea where you might have lost it. If not, there is no way to locate it.
Best Answer07-12-2020 12:02
07-12-2020 12:02
Hi @Cele89 here is the article with some ideas - click to read it.
@SunsetRunner is right. There is no easy way to find it. You can try setting some silent alarms and hope that it will vibrate against something so you can hear it, as long as you can still sync to it.
Let us know what happens.
