My Versa's demise started with it not saving my workouts....I went through all of the help advice. Restarted; deleted app and downloaded it again; re synced to another device-nothing; tried to reinstall and it said "abort." Yesterday time was 4 mins off and then it just died, no green lights and it was charged at 81%. I'm pushing the left button and it will not restart. Now what? I haven't had it a year yet!
My Versa also died after the update last night. I too tried all the suggestions for restoring it but nothing worked. My Fiitbit is less than a year old ,so I really believe the upgrade had some to do with it dying.
Best AnswerSame Here, and they gave me the choice 50% off and Upgrade. I just wonder is that a New Versa or an refurbished one?
Best AnswerI know, I haven't made my choice yet.
Best Answeri chatted with service and after a half hour of chatting I was given the option of a new Versa or 50% off another model. I’m getting another Versa. Worth the phone chat for sure. Good luck.
Best AnswerI bet you’ll get a new one then. I just got an email saying mine is on the way. I can’t wait 😊 I hope it all works out for you. Thanks for the support!!
Thank you, I decided to go with the replacement, I hope it is a New one too. I hope it works out for you too.
