08-07-2018 00:46
08-07-2018 00:46
My Versa's last sync was Sunday morning. For no reason I can think of it hasn't synced since. Yes, I've tried all the suggested steps to get it back, but nothing's working. Totally frustrated. Can anyone help?
08-07-2018 03:32
08-07-2018 03:32
What phone are you using?
Helen | Western Australia
08-07-2018 03:35
08-07-2018 03:35
iPhone 10.
Ive done everything suggested and been trying all day.
it just keeps spinning when it gets to ‘connecting to tracker’ stage.
08-07-2018 07:30
08-07-2018 07:30
I have the same issue. Worked for several months and have suddenly stopped syncing. Tried everything still nothing. I use iphone6
@Beads wrote:iPhone 10.
Best Answer08-07-2018 07:42
08-07-2018 07:42
It's difficult to recommend things to try without knowing what you have tried already. If you really have tried everything then what's left for us to suggest?
Both phones mentioned are on the list of supported phones so that's good.
The usual steps to try are:
Best Answer08-07-2018 07:51
08-07-2018 07:51
Thanks for your suggestion and I have tried everything that you mentioned.
@SteveH wrote:It's difficult to recommend things to try without knowing what you have tried already. If you really have tried everything then what's left for us to suggest?
- restart phone
- restart fitbit (several times)
- forget fitbit in phone's bluetooth settings
- go through fitbit's troubleshooting guide at: https://help.fitbit.com/articles/en_US/Help_article/1866/
- and finally, as it says in that guide, if it still won't sync then contact customer support
- restart phone
- restart phone
Best Answer08-07-2018 07:53
08-07-2018 07:53
Then it's probably best to contact customer support: contact.fitbit.com
Best Answer08-07-2018 13:16
08-07-2018 13:16
Many thanks. Will try all those alternatives again today and thanks for the link to troubleshooting.
