Hi @PujaP , is the green sensor light at the back of your watch on? If yes, try the following:
1. Go to the settings of your Versa and turn HR off.
2. Restart your Versa three times with the two buttons method.
3. Go to the settings of your Versa and turn HR back on.
4. Sync with your Fitbit app.
Hope this helps, regards kuzibri
Best AnswerHi, since this did also not solve your problem, call Customer Support and tell them what you already did to solve the problem, this will help. Regards kuzibri
