07-22-2019
07:39
05:03
07-22-2019
07:39
05:03
I bought fitbit versa 3 months back from Flipkart .From last two days it had battery life issue but today it's not turning on.
I need assistance.
07-24-2019 05:26 - edited 03-27-2024 06:13
Welcome to the Community Forums @Vedantrajmishra! I'm sorry for the late response.
Please try charging your Versa for at least 1 and then perform a restart on it by following these steps. If the restart doesn't work and the display is still not turning on even after the recommended steps. Please take a look at the help article Why isn't my battery charging?
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Best Answer07-24-2019 05:26 - edited 03-27-2024 06:13
