05-14-2018 18:03
05-14-2018 18:03
My versa will randomly buzz my wrist. There are no notifications coming through when this happens (those work just fine, no issues for calls/texts) just a random quick buzz.
I don't have move notifications set up, but this has only happened since the update.
05-15-2018 06:44
05-15-2018 06:44
I have the Nothing Special watchface too. I contacted the developer and they said the random vibration is an issue they knew about and they submitted a fix last Friday. I just went to my clock face settings and noticed there's an update, so I have installed it. Hopefully this gets rid of the random vibration.
05-14-2018 18:08
05-14-2018 18:08
It may be that you met your step goal.
one cruise ship at a time!05-14-2018 18:21
05-14-2018 18:21
@DramaQueenDiva wrote:It may be that you met your step goal.
Yes, most likely; it usually displays a screen of fireworks once the goal is complete. I just have my goal for distance set at 5 miles, and this happens with multiple tiny vibrations at once when this goal is achieved. The other explanation could be that she's got a watch face that has vibrate on disconnect/reconnect feature.
05-14-2018 19:34 - edited 05-14-2018 19:38
No. I've had a fitbit for 3 years, I know what it's like when I hit my step goal. While I've only had the Versa a short while, it is not the same buzzing as when I hit my goals. This is a small tiny buzz. This has only happened since the update. I haven't changed my watch face either, in the time I've had it. So unless something has happened to the watch face since then....
It is still randomly buzzing. Just a quick short buzz. No notification buzz, no buzzing because I met the goal, etc. Nothing shows up on the screen, just a quick buzz
05-14-2018 19:44
05-14-2018 19:44
Yep , that sounds like disconnect vibration. What watch face are you running?
05-14-2018 20:29
05-14-2018 20:29
"Nothing Special"
05-14-2018 20:45 - edited 05-14-2018 20:45
Last I remember (when I had used that watch face), that watch face has settings for disconnect vibration.
05-15-2018 06:31
05-15-2018 06:31
I looked through the settings, didn't see it, but I will look again.
05-15-2018 06:44
05-15-2018 06:44
