05-12-2018
12:47
08:51
AlejandraFitbit
05-12-2018
12:47
08:51
AlejandraFitbit
Hi! I purchased a Versa and have had it now for a week and have yet to be able to really use it. I have tried to set it up at least 7 times. The Versa itself tells me it is updated, but the Fitbit app says it needs to update. Every time I try to get the Versa to update as the app says, it won’t connect to the versa. I don’t get notifications but the worst part is that the data from the versa won’t sync to the app. This is absolutely aggravating. Please help.
05-12-2018 15:01
05-12-2018 15:01
Same thing is happening to me. I’ve tried to do hard resets, disconnect the blue tooth, etc.
The last time in synced was last night when I did the software update. Super annoying.
08:53
10:43
05-14-2018
08:53
10:43
Hey @SunsetRunner and @Ckelley11 a warm welcome to the Community.
Thanks for troubleshooting this by yourselves. If your trackers aren't syncing, I recommend taking a look at the Having trouble syncing? post and follow the instructions provided there. If the issue is directly with update them in the Why can't I update my Fitbit device? article you will see some steps to follow.
Let me know the outcome. ![]()
