10-29-2020 01:10
10-29-2020 01:10
Hi everyone
My versa screen went black so I tried to reset it, but the Fitbit logo never came on. I have it on charge but the screen won't light up and there's no green light. HELP!!!!!
10-29-2020 02:07
10-29-2020 02:07
Bonjour
J'ai exactement le même problème depuis 15 min.
Aidez moi. Merci
Best Answer10-29-2020 03:52
10-29-2020 03:52
Mine quit working also☹️ I started having problems yesterday. It seems to have started since updating app
10-29-2020 04:07
10-29-2020 04:07
Mine stopped working on Monday still no life,
Best Answer10-29-2020 04:36
10-29-2020 04:36
Mine too it started yesterday. Now the screen is black and it wont even charge.
Best Answer10-29-2020 04:40
10-29-2020 04:40
Mine is doing the same thing.
Best Answer10-29-2020 04:56
10-29-2020 04:56
Mine is also.
Best Answer10-29-2020 06:26
10-29-2020 06:26
So is mine.
Best Answer10-29-2020 06:27
10-29-2020 06:27
I went to bed last night with my versa charged at 66% and now it isn't working. I contacted fitbit this morning and they want me to send my watch back for replacement since it is less than a year old. I also asked if it could be a possibility that there is a virus/bug and they stated they couldn't identify a problem unless it was sent back.
Best Answer10-29-2020 06:55
10-29-2020 06:55
Same here
Best Answer10-29-2020 07:00
10-29-2020 07:00
Hi, same thing happened to me - called 0800 069 8505 (uk no to call Fitbit) - talked with someone who said to hold down the left hand button and the bottom right-hand button at the same time for 12 seconds. The blue triangle then came on. He said to fully charge it, go into the Fitbit page and on the top-right hand side you should see that an "update pending". Worth a try.
Best Answer10-29-2020 07:07
10-29-2020 07:07
Best Answer10-29-2020 08:44
10-29-2020 08:44
Vous a t'on trouvé une solution ?
Best Answer10-29-2020 09:03
10-29-2020 09:03
I just did the new tracker update and also now have black screen. I started the update at 80% battery, also put in the charging unit. All went fine, quick update. App looks like new features are installed. When I removed from the charging unit the screen went black. Plugged into the USB on my laptop, my PC said doesn't recognize the device, device malfunctioned. I guess my advice to all if you are proactive and reading this first, don't do the update on your tracker. Mine is a Versa 2, less than a year old.
Best Answer10-29-2020 09:38
10-29-2020 09:38
The funny thing is I haven't even completed the new update and randomly woke up to a black screen.
Best Answer10-29-2020 09:39
10-29-2020 09:39
Hello, see my message further up (based on advice given today by Fitbit) - I hit a problem in that my desktop computer would not update it (several attempts). I then used the app on my mobile phone and it is currently uploading as I type! Hope this helps. He also said to ensure the Fitbit was 100% charged or near to that.
Best Answer10-29-2020 09:47
10-29-2020 09:47
Mine too
Best Answer10-29-2020 13:55
10-29-2020 13:55
Me too! Very frustrating and now it doesn’t seem to want to turn on or connect to app.
Best Answer10-29-2020 13:59
10-29-2020 13:59
Tried everything. Nothing seems to work! The support endlessly repeats the same thing over and over again even when it's not working. Extremely frustrated with fitbit!
