I charged my Versa this morning, it was 100% when I put it on, the I logged 3000 steps walking a dog. When I looked again at my Versa, several hours later, nothing showed. It is black and non responsive. Help. I’ve on,y had it about 2 1/2 months and it s never been dropped or gotten wet.
Best Answer@Cynthavl To restart your Versa hold the left and bottom buttons at the same time until you see the Fitbit logo appear (about 10 seconds) then let go. If the battery is dead, put it on the charger to give it some power because a dead battery won't restart. I had one Clock face cause my Versa to run down very quickly. If your Versa successfully recharges and reboots, consider a different Clock Face to check if that's the root cause.
Best AnswerI have had my Versa for only about 3 months. I had to return it because it would not charge. Had it on the charger for about 12 hours and got no charge. I checked the charger to make sure it was working properly. I have had several times when the screen would go black and would return on it own. I have had times when I pushed the button to check the time and the screen would not respond. I finally called FitBit and was told to return the Fitbit. I returned it on August 5 and it was only today August 18 that they told me they were sending me another one. Have anyone else had similar problems with Versa?
Best AnswerUnfortunately many.
Best AnswerMine too!
Went to bed last night (17 august) working fine as i literally checked the time as i was in bed. woke up this morning at 8 and it has black screen no Bluetooth syncing. Tried resetting several times but just get a quick vibration and green light briefly flashes underneath. No screen. No fitbit logo. Only purchased in April.
Can't shut down as black screen. Tried contacting fitbit via app but no response so can't even send back under warranty. Any suggestions?
Best AnswerI called their customer support 877-623-4997; they were very supportive, sent me the paperwork to return the fitbit to them. I just got word today that they will replace the it and it has been shipped. This took almost 25 days.
