05-07-2019 11:18
05-07-2019 11:18
Fitbit Versa keeps disconnecting , setting says a phone restart is required ??? This is the 4th time today, unacceptable 🤬 I took a screenshot of the message from the app but it can't be posted here 😵 All help appreciated
Dave
05-08-2019
07:15
08:03
05-08-2019
07:15
08:03
Hello @Davecp2008 thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience with us. At this moment, I would like to gather some information from you so we can check this further:
Thanks for your patience and understanding, we'll be waiting to hear from you.
05-08-2019 07:36
05-08-2019 07:36
The phone I'm using is the Huawei P30
IMUI version 9.1.0
Android version 9
Fitbit app firmware version 32.33.1 30
The photo insert instructions are not like I'm seeing here on the app on the phone?
3 boxes appear for information to be entered
1 source
2 image description
3 dimensions
We're Whese instructions for use on a PC?
05-09-2019
09:42
08:02
05-09-2019
09:42
08:02
Hello @Davecp2008 I hope you're doing well, thanks for taking the time to reply and for providing the information requested.
Indeed, the instructions sent are to use in a pc. If you're using your mobile device, when you hit reply, you will be able to see a camera icon on top of the text field, tap on it and you will be able to choose a picture from your phone. Select it and after entering your message, hit Post.
Thanks for your patience and understanding, we'll be waiting for your next reply.
05-15-2019 04:27
