05-29-2020 23:47
05-29-2020 23:47
My versa lite. Is showing the wrong time and won’t sync. I’ve tried disconnecting it from app. And Bluetooth. I’ve turned phone and watch on and off but nothing is working to sync it.
any ideas please?
05-30-2020 09:46
05-30-2020 09:46
Hi @Annieknights your tracker is not syncing, therefore the time is off.
Removing the tracker from the phones bluetooth is a good idea. Removing the tracker from your Fitbit account will usually add more problems.
Have you been able to setup the tracker to your Fitbit accoint?
May I ask what model phone are you asking about?
05-30-2020 10:34
05-30-2020 10:34
05-30-2020 10:58
05-30-2020 10:58
My Fitbit is connected to my app it took ages to reconnect but it did connect. Just won’t sync. says device not found.
im on iPhone
