09-25-2020 06:55
09-25-2020 06:55
I have the versa lite fitbit.. I do the leslie walking dvds.. just had twins and tubes tied/removed go the 7th to hopefully get cleared to exercise again.. my question is my other fit bit neither one would track my leslie workouts on my other it let me add in my exercise (how long it took/how far it was in miles) and it added it to my steps and such for me.. how do you do this on the versa lite I can't figure it out
Also my other fitbit had where it was just a regular map and you hit start and you could walk around then hit stop and it would measure how long it took how many steps and such..the one thing I found on here it doesn't work the same way I can't figure it out
Best Answer09-25-2020 07:13
09-25-2020 07:13
Hi, @Sweetkarin , I am not familiar with the Leslie Workouts, but a quick google suggests that this is basically a brisk walk, which you should be able to easily track with your Versa lite.
As you want to know your distance as well as your steps, you will need to do this using the Exercise App on your Versa Lite.
First, you need to make sure that Walk is one of the exercises on your Versa Lite. You can check this on the Fitbit itself, or you can do this on your phone/tablet that you use to sync your Fitbit. I’ll give you the instructions for your Fitbit, as that is the simplest.
On your Versa Lite, swipe left until you see the running man icon for exercise. Tap on the icon. On the next screen swipe left until you find Walk (hopefully it will be there!).
When you come to the Walk screen you will see a little gear icon top left. If you tap on the gear icon you will see options to customize your display while you walk (so you can check as you go along). Also, if yu would like a map of your route you can choose to turn on “connected GPS” - this will use the GPS on your phone to create the map.
Once you are happy with the settings and ready to walk, go back to the Walk screen, tap, and the next screen just requires a tap to get started (Let’s go!). At the end of your walk be sure to tap the pause symbol (bottom right) and then the finish flag (top right).
Once you sync, all yur stats for your exercise should be there.
I hope this helps. If you need more information, please post again and let us know which phone yu use so we can give more details.
And many congratulations on the twins! I guess you are going to have your hands full for quite some time! (Do take it easy...)
Best Answer10-18-2020 16:17
10-18-2020 16:17
I did this exactly but no map showed up.
