06-10-2019 08:53
06-10-2019 08:53
It's not tracking my heart rate or steps. The pulse sensor light is not turning on. Steps reading "0" zero as well. I have reset/ turned off the versa lite and still not sensing.
Best Answer06-11-2019 18:49
06-11-2019 18:49
Welcome to the Fitbit Community @Lew2you.
I'm sorry to hear that your Fitbit Versa Lite is not tracking your heart rate nor your steps. Thank you for restarting and turning off your device before contacting us. Please open the Settings app on your watch and make sure Heart Rate is set to On. You can also turn the setting off and back on to see if there is any change.
If this doesn't work, please perform a factory reset of your Versa Lite by following the steps below, but keep in mind your apps, stored data, personal information, credit and debit cards, and saved settings will be removed from the device:
On your Versa Lite, open the Settings app > About > Factory Reset or Clear User Data.
Please let me know if you have any question.
Best Answer04-29-2020 21:28
04-29-2020 21:28
Hello,
I'm having the same problem with my daughter's fitbit versa lite. I have updated her iphone, uninstalled and reinstalled the app, restarted the fitbit, I tried a factory reset on the fitbit, and switching clock faces. Still the heart rate nor steps are tracking.
Thank you for any advice!
Best Answer04-30-2020 08:26
04-30-2020 08:26
Contact customer service. I had to get it replaced.. twice. Sorry
Best Answer04-30-2020 08:41
04-30-2020 08:41
Was it difficult to get replaced? It was a gift, so I don't even have a receipt. Thanks!
