08-16-2018 14:51
08-16-2018 14:51
Woje this morning to find my versa was an hour behind real time, been trying to fix it all day but got nowhere as it now isn't synching. Lost more time during day, I'm now 90 minutes behind real time,, anyone else had this issue?
Best Answer08-16-2018 15:04
08-16-2018 15:04
Try a Restart and do it several times if necessary.
Best Answer08-17-2018 03:49
08-17-2018 03:49
Best Answer08-17-2018 04:16
08-17-2018 04:16
Sounds like your Versa is not staying linked to your phone. I would delete the connection and try connecting again. Do it after a sync so you do not loose any info.
Best Answer01-26-2019 19:13
01-26-2019 19:13
My husband and I both have a Fit Bit Versa, his keeps losing time and has issues syncing and I have never had an issue with mine.
I contacted Fit Bit regarding this and the only thing they where able to tell me is that it is his phone. My husband has an Lg6 they said it was never tested compatible with that phone.
I have to connect it my Samsung to get the time fixed, and it might last 1-2 days before it happens again!
They should really tell you when you purchase their $200+ Fit Bit it might not work with you phone!
Best Answer01-26-2019 23:26
01-26-2019 23:26
Best Answer09-01-2019 05:57
09-01-2019 05:57
Just to be clear, your issue was fixed by getting a new watch? I am having the same problem. I am always 20 minutes behind and have tried everything. I guess it is time to call unless someone else has a fix.
Best Answer09-01-2019 14:27
09-01-2019 14:27
