02-16-2019 17:18
02-16-2019 17:18
Sorry for making u guys type so much but could u pls make a full list of what you can do without a phone present.
I’m gonna get the Ionic but the Versa just looks so much better so I’m doing this to know weather I’ll need the Ionic.
thanks!
Best Answer02-16-2019 17:26
02-16-2019 17:26
Hi, if you want to use the Versa without a phone, you have to read this article about "Setting up your Fitbit Device". Click on the link and then on "Trackers and Watches" and scroll down to just underneath the first video where its says "Fitbit Connect" and read that thoroughly. Good luck!!
02-16-2019 17:36
02-16-2019 17:36
Hi @SunsetRunner i have both the Ionic and the Versa and basically they are idendical in their operation with the exception of GPS. If you want to use GPS, with the Ionic you can do that without your phone with you as it has inbuilt GPS. With the Versa you will need your phone. I never use GPS so for me their operation is identical.
Helen | Western Australia
02-16-2019 22:38
02-16-2019 22:38
Besides not having the connected gps, you will want to disable this feature, notifications from a phone will not happen.
With the Win 10 app I believe all other features may be accessed.
