06-11-2018 18:17
06-11-2018 18:17
When I start an exercise ie run my versa often does not connect to my gps. It just says connecting. Sometimes it does connect for a bit and then goes back to connecting. I always have my phone with me. Is there something I can confirm will work outside of wifi areas? The areas it does work seem to be wifi areas for the most part. This also just started since my last Fitbit update. It used to always work.
06-12-2018 01:06
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
06-12-2018 01:06
When mine takes too long to connect, I force close and restart the app on my phone, and this usually helps. It is much slower to connect than my Blaze was though!
Best Answer06-12-2018 01:46
06-12-2018 01:46
Leave the app open and running in the background on your phone. Doesn't have to be on screen, just open. Works every time that way for me.
Best Answer06-12-2018 05:26
06-12-2018 05:26
Best Answer06-12-2018 05:27
06-12-2018 05:27
10-03-2019 09:49
10-03-2019 09:49
I have tried everything. The only solution left is to switch to a Garmin
