01-18-2019 07:13
01-18-2019 07:13
I can't seem to keep my versa connected to any WiFi long enough , then when I switch from my data to WiFi it's gone , keep having to re-install my versa device which is quite annoying , other device s I have are grand , but this is annoying me especially with the Bluetooth on my Huawei phone . Anyone else got that problem ..??
01-18-2019 12:49
01-18-2019 12:49
@Murph19 Can you elaborate? Have you added WIFI network in your Fitbit mobile app (tap on Versa icon and scroll down to WIFI Settings)? Wifi is only useful if you're planning to perform a firmware update on your Versa, download music to it, or install large clock faces (e.g. Fitbit labs clock faces) or large apps (e.g. Fitbit Coach). All sync happens via Bluetooth connection - your stats, notifications, etc. I found out that having Wifi added, interferes with my BT connectivity sometimes, so I always remove the network from Fitbit mobile app.
01-18-2019 13:29
01-18-2019 13:29
01-18-2019 13:38
01-18-2019 13:38
@Murph19 You do not need WIFI for notifications as I mentioned before. If you do not receive them, they're either not configured properly or your bluetooth connection with Versa is not stable. First of all, what's your phone model and OS. Also, what's your Versa firmware version and fitbit app version? Does your Versa sync without issues? When was the last sync (open fitbit app, tap on the Versa icon, and scroll down to the Sync section).
01-18-2019 13:47
01-18-2019 13:47
Wifi I have never been able to get this to work it says wifi is off but ant find the option to turn it on
01-18-2019 13:48
01-18-2019 13:48
01-18-2019 21:32
01-18-2019 21:32
@SunsetRunner You add or remove Wifi in your Fitbit mobile app (tap on Versa icon and scroll down to WIFI settings). You do not do anything on Versa itself. Just remember to sync after adding or removing WIFI network within Fitbit mobile app. Also, remember to put Versa in the charging dock when you want to use WIFI so not to run into battery issues. WIFI will not work if the battery is below 25%.
01-19-2019 00:44
01-19-2019 00:44
01-19-2019 19:19
