04-18-2018 16:51
04-18-2018 16:51
My Versa is not counting my steps accurately at all. I’ve lost thousands of steps today. Any ideas?
07-24-2018 18:55
07-24-2018 18:55
07-24-2018 20:24
07-24-2018 20:24
I have called support several times. I get the same response each time. Versa On/off, delete and re-install the app, Update app, swing arms more when walking.
07-24-2018 20:52
07-24-2018 20:52
08-30-2018 06:52
08-30-2018 06:52
I'm running into the same issue. I'm down about 15-20% of my steps.
I tried walking in a straight line and it only counts 70-85 out of 100 each time.
I don't understand why it counts less steps than my flex 2. Did the Pedometer get worse?
01-12-2019 14:39
01-12-2019 14:39
Thanks for this info! So far it seems to be helping... Much appreciated.
01-12-2019 15:27
01-12-2019 15:27
Nvm. Worked for an hour, then relapsed.
12-06-2019 07:23
12-06-2019 07:23
Walked fast for 45 minutes this morning. Fitbit only tracked 666 steps. This is wrong
12-07-2019 01:40 - last edited on 05-22-2020 19:33 by LiliyaFitbit
Make sure you swing your arms like a chimpanzee. For me, the Versa normally counts 30-50% of my steps. And the heart rate monitor is only in the ballpark (less than 10% error) 80% of the time.
12-08-2019 15:44
12-08-2019 15:44
12-08-2019 22:51 - last edited on 05-22-2020 19:32 by LiliyaFitbit
Well, I went hiking today with my Versa, and for a change, it did a fairly good job counting “steps”. It was about 10% higher than the steps counted by the Pacer app on my iPhone. Not accurate but better than its usual 30-50% low. I also got a Lighthouse badge from Fitbit.
