01-17-2021 06:51 - last edited on 01-17-2021 12:18 by LiliyaFitbit
my fitbit versa does not count steps. I have tried all the suggestions listed to try and reset it, including turning off etc. There appears to be no dirt in it nor is it too tight on my wrist.
01-17-2021 07:44
01-17-2021 07:44
If you have tried restarting the watch and it did not fix it,
you probably need to reload your watch face or re-grant permissions
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Clocks click on the clock you are using and See all details and remove the permissions, exit out and sync your watch Repeat the whole process and reapply the permissions and re-sync the watch. It may need restarting after.. |
Hope that helps.
Best Answer01-17-2021 07:45
01-17-2021 10:53
01-17-2021 10:53
11:01
08:19
01-17-2021
11:01
08:19
