Versa not detecting sleep
I got my tracker three days ago and have been wearing it to bed each night. I checked in the app and the my last night's sleep that was detected was with my old tracker. Please help
4 REPLIES 4
A warm welcome to the Community @Laurenam8783.
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
I hope this helps, let me know the outcome. Smiley Happy
@AlejandraFitbit
I do understand that, however, my tracker is not even showing any hour
being slept.
Thanks for the update @Laurenam8783. Since the troubleshoot didn't work, I've gone ahead and escalated your case to our Support Team, for them to take a deeper look at this, please keep an eye on your inbox for further instructions.
Let me know if you need anything else. Smiley Happy
I am having the exact same issue and need help.
