03-10-2019
18:11
19:42
EdsonFitbit
03-10-2019
18:11
19:42
EdsonFitbit
I have had my Versa since May of 2018. I have been very happy with it until about 6 weeks ago. Generally a charge will last about 4 days. I usually put it on the charger in the morning while getting ready for the day. It is usually at about 75 to 80 % by the next morning. I always check before putting it on so I know it is at 100% when I put it on. 6 weeks ago I was at work and the battery went dead. I did a reset, charged it and it was ok for about a week. Now it will randomly experience full battery drain in about 6 hour At least once or twice a week. I have done all the resetting, cleaning that is recommended. I am not using any new apps or settings. I would like to either have this issue resolved or the versa replaced. It isn't even a year old.
03-10-2019 21:31
03-10-2019 21:31
I’m having a similar issue, I charged mine for several hours today, it was at 100%, put it on, & 7 hours later it’s at 74%
Best Answer03-12-2019 19:41
03-12-2019 19:41
@cwagner58 @Shell7609 Welcome and thanks for visiting the Fitbit Community. Sorry for the delayed response.
I regret to hear that your Fitbit Versa watches are not holding a charge. Thank you for the time you spent trying to get it resolved. To evaluate your cases, I sent your information to Customer Support. Please check your inbox on the next days. They will do their best to find a solution as soon as possible.
If you have any question, please don't hesitate to contact us at any time.
Best Answer03-13-2019 15:16
03-13-2019 15:16
