01-22-2019
03:09
10:35
MarcoGFitbit
01-22-2019
03:09
10:35
MarcoGFitbit
My versa has stopped recognising my step count and won’t Autowake. I have checked the settings and all seems right. I have also tried the reset 5 times on the watch.
Can anyone suggest any other tips before I contact customer support. Many thanks
Best Answer01-22-2019 13:18
01-22-2019 13:18
@SunsetRunner have you tried restoring it to factory defaults (factory reset)? This will wipe your Versa, so please sync first. You will also need to delete your tracker from the Fitbit account (in the Fitbit mobile app) and your Paired Devices list in your phone Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a new device in the Fitbit mobile app. Good luck!
01-22-2019 13:45
01-22-2019 13:45
Best Answer01-22-2019 15:29
01-22-2019 15:29
My versa is having a similar issue I contact Fitbit team and they told me that there is a problem with the steps syncing that they are trying to fix the problem I asked when will they be fixing it and they could not give me a date it’s very frustrating. My problem with my versa is not sync steps to my challenges. I hope that helps
01-22-2019 20:02
01-22-2019 20:02
@SunsetRunner Does it say data not cleared? Try rebooting your Versa (press and hold the left and bottom right buttons until fitbit logo flashes) and rebooting your phone. Then open fitbit mobile app and try to sync. Lemme know how it goes.
01-22-2019 23:19
01-22-2019 23:19
Best Answer01-23-2019 02:35
01-23-2019 02:35
Yeah I’m having that exact issue, Versa not posting or registerering the step goal within challenges, started on Monday January 21.
Best Answer01-23-2019 03:10
01-23-2019 03:10
Best Answer01-23-2019 03:28
01-23-2019 03:28
Best Answer01-23-2019 11:38
01-23-2019 11:38
@SunsetRunner I thought your tracker did not register steps at all. @Jeff_w26's case is different. He gets steps but they're not synced to his challenges. Or did I get it wrong? 🙄
Best Answer01-23-2019 12:04
01-23-2019 12:04
Best Answer01-23-2019 12:10
01-23-2019 12:15
01-23-2019 12:15
Best Answer01-23-2019 12:19
01-23-2019 12:19
@Jeff_w26 happy stepping, Jeff. In your case it's obviously a software bug that affects only certain group of users and not issue with the tracker itself. I'm afraid, we have to wait.
Best Answer01-23-2019 14:54
01-23-2019 14:54
01-26-2019 10:41
01-26-2019 10:41
Hello @Jeff_w26, @SunsetRunner and @Montemayorjanet, I hope you're doing well, it's nice to see you around the Fitbit Community. It's nice to see you too @Marrrmaduke, thanks for your help with this situation. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. I would also like to thank you for letting us know the response from our Support Team. Our development team is aware of it and is working towards a prompt and proper resolution for this situation.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track. Please let us know if there's anything we can do to assist you in the meantime.
