Versa not swiping
Versa is about 7 months old, it's not swiping up or down or side to side. Stats are showing up on the main screen. I have done multiple resets and am considering a factory reset. If I factory reset, will it remove all the data out of the app on my phone or just clear the data on the versa?
1 REPLY 1
Hey @SS_5, it's great to see you around.
Thanks for troubleshooting this by yourself. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution.
Catch you later. Robot Happy
