02-11-2019
20:06
10:49
MarcoGFitbit
02-11-2019
20:06
10:49
MarcoGFitbit
Hi guys,
I was wondering if someone can contact or email regarding my fitbit issues. I bought my fitbit versa in 7/3/18 and I don't do updates and sync my watch to the latest. For some reason the second right button doesn't work anymore when i pressed it. Doesn't vibrate at all.. I used to be able to track or see how many steps I have on the screen, miles, cals and female health, but now only time, day and heart rate are working.
Please contact them yourself
Contact Support.
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Wendy | CA | Moto G6 Android
Hello @U2_0, have a warm welcome to the Fitbit Community, it's great to have you on board. It's nice to see you too @WendyB, thanks for all your help. ![]()
@U2_0, I appreciate your participation in the Forums and for sharing your experience with us. At this moment, we're going to try to adress all of the issues you're experiencing by performing a factory reset on your Versa. Keep in mind that this will remove any data that hasn't been synced, your settings and the apps you have downloaded, but it will be helpful to make your Versa sync, update and might be able to help with the button issues you're experiencing.
To perform a factory reset go to the Settings app on your Versa, then tap on About > Factory Reset. After that, you will need to set up your Versa as a new device:
I hope this can be helpful, if you're having trouble setting up or updating your Versa afterwards, please refer to my post with troubleshooting steps that I'm sure will be helpful.
Thanks for your patience and understanding, give it a try and let us know the outcome.
