10-17-2018
23:16
08:55
AlejandraFitbit
10-17-2018
23:16
08:55
AlejandraFitbit
I purchased my Fitbit Versa in US on June 15, 2018. I reside in Chennai, India. Suddenly last night my screen went blank. I tried charging, the charge is 80% on my device. I read about the similar issue in the forum and they have advised for soft reset. I tried that too... still the display shows dull colors sometimes and still dead. Please advise how can this be rectified.
Best AnswerTry a factory reset. Let us know if that helps.
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
10-19-2018
08:56
06:43
10-19-2018
08:56
06:43
It's great to welcome you @Mahavenkat and @NellyG thanks for stopping by.
I would like to know if the instructions provided by our friend worked? Are you still having issues turning on your watch?
Hope to hear from you soon. ![]()
Best AnswerThe solution didnt work, however i contacted the voice support and they did something and it worked... 🙂 Yay!!
Thank you for the responses.
But now, again i m facing the same issue. I do not know what to do... 😞
Regards,
Maha
