02-03-2019 06:30
02-03-2019 06:30
Hi,
I recently got a Versa and used it for the time this past Friday. During my workout, I noticed it kept pausing every 5-10 min (boot camp mode). Not sure if it was doing it on its own or if my hand would accidentally hit the bottom right button. I wear my watch on my left hand so I strongly suspect it was my hand that was causing it to stop. Is there anyway to disable that button/feature?
Best Answer02-03-2019 18:13 - edited 02-03-2019 18:13
@Perez85 unfortunately there's none.other users have reported this issue as well. I believe there's a thread requesting this feature on Feature Suggestions Forum. Please vote for it. If there's no thread, please create one! 😊 Just to be sure, reboot your tracker several times by pressing and holding the left and bottom right buttons until Fitbit logo appears.
Best Answer02-10-2019 05:13
02-10-2019 05:13
I'll give this a try and let you know. If this persists I will definitely post again.
Thank you.
Best Answer02-10-2019 17:37
02-10-2019 17:37
@spinner328 thank you and good luck! 👍🏻
Best Answer02-10-2019 18:41
02-10-2019 18:41
Mines does the same thing.
Best Answer02-23-2020 15:38
02-23-2020 15:38
Super annoying when you finish a race and go to stop it only to see that it paused at mile 2.3.
Best Answer05-06-2021 16:38
05-06-2021 16:38
Mine does this too, especially when doing things like burpees, or even when I switch weights from one hand to another.
