12-27-2018 10:47
12-27-2018 10:47
Hi why can I see answer and reject calls but my watch will not answer them???
Best Answer12-27-2018 12:10
12-27-2018 12:10
12-27-2018 11:11
12-27-2018 11:11
Hi, as the name already states, the Versa gives you only the notification of a call. You cannot answer this with your Versa cause it does not have a microphone. It only tells you by notifying, that you need to go to your mobile device and answer the call or call back.
Best Answer12-27-2018 11:39
12-27-2018 11:39
Hi why does it have an option to answer the call then?
Best Answer12-27-2018 11:48
12-27-2018 11:48
did you enable "Quick Replies"? You can set these replies up under notification, scroll down to Quick Replies and there you will see a list of enabled notifications. Quick replies are only for apps, like calendar events, email, and the like. For each of them you can choose the quick reply of your choice. For calls, this is difficult is such a way that the Versa has no microphone.
12-27-2018 12:10
