04-25-2020 01:07
04-25-2020 01:07
Not sure what is going on, but my versa is acting like it is dead and will just turn off and wont come back on till I connect it to the charger, then who knows how long it will stay on. It was perfectly fine before it got the last software update now I am not sure what is going on and I am very un happy about it as I use my fitbit to track everything I do fitness related. Please help!!
04-25-2020 01:55
04-25-2020 01:55
Hi @zkuebler Try restarting it several times, if you havent already. Also try a Factory reset (settings app on the watch and scroll down to About). If it still randomly switches off, Support is your only option,
Helen | Western Australia
Best Answer04-25-2020 01:56
04-25-2020 01:56
Hi,
What update was that? I have got the 32.70.7.27 and everything seems fine.
You can check her the changes and a Tutorial how to find what changed on the Fitbit help. https://www.revick.net/news/fitbit-versa-update-32-70-7-27-38-70-7-27/.
You can also try doing a hard factory reset following the below steps from Fitbit Support:
you can perform a factory reset to your watch by following the next steps, but keep in mind that your apps, stored data, personal information, credit and debit cards, and saved settings will be deleted from your device:
Best Answer04-25-2020 02:28
04-25-2020 02:28
