11-04-2021
11:21
11:42
11-04-2021
11:21
11:42
my screen isn't as bright as I need it to be. How can I make it brighter?
Hi there, @Doogins. Welcome to the Community Forums.
Have you checked if the brightness has been set correctly? To do so, swipe down from the top of your screen. After your notifications appear, swipe down again to open the control center. Tap the brightness setting icon.
If the above doesn't work, please check if your Versa isn't in sleep mode. When you turn on the sleep mode setting:
I've moved your post to the Other Versa Smartwatches board for organization purposes.
Hope that helps.
Best AnswerI've been having a similar issue, when I'm outside I can't read it at all. When indoors its fine. It is not on sleep mode, and I have 3 brightness settings and it doesn't seem to matter which one I select it doesn't change the brightness at all. I've done a factory reset to it and it still is doing the same thing. Any help is appreciated.
I'm having the same issue with my Versa 2. It was fine, but lately it is way too dim. It is not in sleep mode and I have set the brightness level to max - no difference.
