09-25-2018 19:34 - edited 09-26-2018 19:50
My wife's Versa is acting up with the screen being pixelated & multicolored and it no longer syncing with her phone.
Last sync shows in August, but she didn't realize until today when the issue of the screen started. She's always had All Day Sync enabled.
I think I've seen the pixelation slightly on mine before, but I believe a quick reset was able to fix it. Now with my wife's there is no solution as I've tried reset and there's no way to sync and look for an update.
I assume I have to contact customer support but I'm hoping someone else has run into this.
She recently switched from GS7 Edge to Essential Phone, but that shouldn't matter.
Pixelated multicolored
Best Answer09-25-2018 20:21
09-25-2018 20:21
Her new phone is not a Supported Device, so that is probably the cause of her syncing woes. I would try a factory reset (Settings app on the watch and scroll down to About) for the screen and see if that fixes it id suggest you contact Support (link in my signature)
Here is some syncing Help data from @HeydyF
If your device still won't sync, try these steps:
Helen | Western Australia
09-26-2018 10:45 - edited 09-26-2018 10:46
Hey @steveb944, it is great to see you around more often. Hmmm sounds odd how your wife's Versa is acting up. If after following the very complete troubleshooting that @NellyG posted above, the issue persists, let me know so I can continue assisting you.
Keep me posted!
09-26-2018 19:49
09-26-2018 19:49
Hey @HeydyF, still pixelated.
I just finished the whole wiping, and set up. (It was a breeze once we got on WiFi back home).
I got excited when I finally booted up since it worked on Essential (yay!), but the pixelation is still there throughout all her screens (boo!).
It's almost like a rainbow effect.
I've directed my wife to try and reach out to customer service. I hope they can do something since we're still under warranty.
It's unfortunate this happened to her as I'm the one that convinced her on getting it as she fell in love with mine on release day.
The good thing is we have Best Buy warranty if anything as well.
Best Answer09-28-2018 07:28
09-28-2018 07:28
Hey @steveb944, thanks for your reply! I appreciate you have taken the time to try the suggestions posted and also, for contacting our Support team. I hope that their resolution meets your expectations. For further information about your warranty, you can take a look at this link.
Keep me updated!
09-28-2018 09:06 - edited 09-28-2018 13:08
Try connect Versa with another phone and change screen face. If this does not work, then probably this screen is broken and should get some help from Fitbit (i hope this screen is not fall or sm).
Best Answer09-28-2018 10:32
09-28-2018 11:20
09-28-2018 11:20
Hey,
I am sorry to hear that.
I am a Fitbit Versa user as well.
According to @FerdinandFitbit, the Essential phone which your wife uses "is not a compatible device. Now in cases like this, they could work with Fitbit but it's not guaranteed to work all the time."
I would recommend getting an iPhone (the newest model) or compatible Android phones (the newest model), as they support the Fitbit app. (But before then, clear your data from the Essential one... maybe?)
-AE
Best Answer09-28-2018 13:11
09-28-2018 13:11
Most new android phones is not official Fitbit supported 😉 So i guess that right now there is compatible phone or not problem but problem is in fitbit versa.
09-29-2018 07:48
09-29-2018 07:48
Hey @EAClub2018, I hope you are doin' great! That is correct, there are some phones that haven't been officially released as compatible but they might work with the Fitbit Versa, or work periodically. And yes @urmoluts, there are some Android devices that still not on the compatible devices link. Our team still working on it. 🙂
I will appreciate your time and patience.
Best Answer01-26-2019 10:42 - edited 01-26-2019 10:42
I went through customer service and got a replacement via warranty.
Best Answer01-28-2019 04:17
01-28-2019 04:17
Thanks for the update @EAClub2018! Sounds great that you'll get a replacement under warranty from our Support team.
If you have further questions or comments, let me know!
