11-22-2020
09:21
07:39
11-22-2020
09:21
07:39
My Versa 3 is not lighting up It is 100% charged. One of the lights on the back is red.. the screen does not show the time. But My account seems to be connected on my iPhone. What can I do to correct this?
11-23-2020 12:03
11-23-2020 12:03
Hi there @aliceoneil2001, welcome to the Community Forums. I'm sorry to hear about your Versa's behavior, I understand where your concern is coming from. Thanks for the details provided in your post, I'll be glad to help you.
I'd recommend restarting your Versa by following these steps: How do I restart my Fitbit device?
If the restart doesn't work and your watch has not vibrated during that process, I suggest the steps below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
I've moved your post to Other Versa Smartwatches for organization purposes.
Let me know how it goes.
11-23-2020 12:03
11-23-2020 12:03
