07-19-2018 09:58
07-19-2018 09:58
I went for a run last night and my Fitbit has still not synced the run to strava. I have tried everything, logging out of both and in, checked all authorisation settings etc but nothing has worked. Is there an issue?
Best Answer07-19-2018 12:56
07-19-2018 12:56
First @Dhall003 was your run last night recorded with gps and you see tgetmap. If not. it will not be sent over.
just a note your Versa does not sync to strava. Your Fitbit account is connected to Strava
Best Answer07-19-2018 23:39
07-19-2018 23:39
07:46
08:00
07-20-2018
07:46
08:00
A warm welcome to the Community @Dhall003 and @Rich_Laue thanks for stopping by.
I appreciate all the efforts in trying to fix this issue. If your Fitbit account isn't syncing with your Strava account, I recommend taking a look at this post and follow the instructions provide there.
If the issue persists, but your Versa is syncing properly with your Fitbit account, contact directly Strava support.
Let me know the outcome. ![]()
Best Answer10-10-2018 08:07
10-10-2018 08:07
Fixed yet by any chance Dhall? I had same issue as you around the same time. Tried everything and has never synced again since. From a great device (Versa) to a very crap device if this doesn’t sync
Best Answer10-10-2018 13:19 - edited 10-10-2018 13:20
@Shanman1 please remember that no Fitbit tracker will sync with Strava, it is not the trackers fault.
This sync is strickly between your Fitbit account and your Strava account.
10-12-2018
06:30
08:00
10-12-2018
06:30
08:00
Great to see you around @Shanman1 and @Rich_Laue thanks for the input.
Thanks for troubleshooting this by yourself, I would like to know if you keep having issues syncing your Fitbit account with your Strava account? Have you tried the instructions provided in my previous post? If you haven't, please follow those steps.
Let me know how it goes. ![]()
Best Answer10-14-2018 22:30
10-14-2018 22:30
Thanks for the responses to these threads. I'm a bit shocked actually, but it's all syncing and working again!! (for my last 3 syncs over last 3 days anyway).
How did it get fixed? I know it's sort of the usual troubleshooting steps, updated both apps (Fitbit and Strava), unsynced both of them from each other, and re-synced it. Sounds simple enough, but I am SURE I tried this 2-3 times before and it DIDN'T fix it. I would suggest one thing I did differently this time, was I synced it back from the laptop computer (not within the mobile apps).
So if others have been frustratingly going through this fitbit versa not syncing to strava and have tried everything disconnecting the apps and back again, I'd suggest maybe try doing it from the desktop as opposed to the mobile.
Hope it stays working...
