03-05-2024
08:47
05:25
03-05-2024
08:47
05:25
I have the FB505 Special Edition. It has worked great for quite some time. It has not been damaged in any way and a few months ago it started acting up for no reason. It only works when it feels like it! It will work fine for a day or two then it will go blank. When I try to sync with the app it, it shows it with a 99% charge but won't do anything. When I got it to work at one point, I performed all of the suggested steps to reset everything. I've done this process several times and it still won't work properly.
I think the manufacturers do this on purpose in order to get you to upgrade and buy their newer models.
I am over it and don't think that I will be replacing it with another FitBit. Looking at others to replace it now.
03-08-2024 05:31
03-08-2024 05:31
Hi there, @Smilestarter. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa is still not responding. I understand where your concern is coming from, I will do my best to help you with this!
As our last resort, I'd recommend performing a factory reset on your Versa. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
To perform the factory reset, please try the steps below in the order listed:
