05-12-2021
20:39
05:34
05-12-2021
20:39
05:34
I was updating my Versa then I canceled my update, now all it shows is the Fitbit logo and I don’t know what to do, I tried using every technique I found, and nothing seems to work, please help.
05-14-2021 05:37 - edited 10-09-2024 08:40
Hi there, @ISHIIIEEE. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out. I understand where your concern is coming from.
It seems like you have unpaired the Versa from the Fitbit app, but not from the phone's Bluetooth settings, so your watch is asking you to pair it again. Note the error message you're receiving on your watch's screen usually appears when you've performed a factory reset without first unpairing the watch from the phone's Bluetooth settings.
That being said, please try the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Once you manage to sync your watch to your phone, you can try updating your Versa. For more information, see How do I update my Fitbit device?
Hope this helps.
Best Answer05-14-2021 05:37 - edited 10-09-2024 08:40
Hope this helps.
Best Answer05-16-2021 10:34
05-16-2021 10:34
Hi, thank you for replying but I did what you said and it wouldn’t connect so I restarted it and restarting it didn’t do anything.
05-17-2021 05:00
05-17-2021 05:00
I have tried this process twice now to try and reboot my Fitbit versa2. It is still stuck on the logo and nothing has worked.
Best Answer05-17-2021 05:49 - edited 10-09-2024 08:40
@ISHIIIEEE @Dbattuello I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
05-17-2021 11:30
05-17-2021 11:30
Ok thank you for trying
