07-19-2021
16:51
03:53
07-19-2021
16:51
03:53
I have owned my watch for about 9 months.Ome day it was like it was holding a charge so I charged it.Now the only thing that happens is the Fitbit signal with flash on and off when trying to charge.I have tryed everything.I held the back button for 10secs I've held all the buttons.I even spend more money buying another charger thinking it might be that.Nothing worked!!!Now I can't find a solution.very frustrated!
Best Answer07-20-2021 03:59 - edited 10-08-2023 08:34
Hi there, @Berson. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa prior to posting here. We‘re taking into consideration your comments and sentiments in regards to our products and services.
It seems like you have unpaired the Versa from the Fitbit app, but not from the phone's Bluetooth settings, so your watch is asking you to pair it again. Note the Fitbit Logo flashing on and off usually appears when you've performed a factory reset without first unpairing the watch from the phone's Bluetooth settings.
That being said, please try the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
