07-11-2018 13:16
07-11-2018 13:16
When I swipe up from the bottom nothing happens. How do I get my today stats to show up. I’ve been experience lots of trouble with trying to download the update. Just got the Fitbit 3 days ago and I’ve spoken to 2 representatives and finally get to use it but it’s not all working. Please help! Thanks
Best Answer12-18-2018 14:50 - edited 12-23-2018 22:33
X-posting my answer here:
Today app needs an update. Try checking if there's update for Today app in your Fitbit mobile app (make sure you're running the recent version). If yes, that's great, update. If not plug your tracker for a couple of hours in the charger. It should update the Today app eventually by itself (usually within a few hours).
07-12-2018
05:14
09:56
07-12-2018
05:14
09:56
Welcome to the Forums @Odarley.
Have you tried to restart your Versa? If you haven't, I recommend restarting it by doing the following:
I hope this helps, let me know the outcome. ![]()
12-17-2018 13:18
12-17-2018 13:18
I have the same problem and have tried this but it makes no difference
Best Answer12-17-2018 23:22
12-17-2018 23:22
Hi, I’m also unable to see my today stats, this is after updating my Fitbit versa. I’ve restarted it a couple of times but it still isn’t working
Best Answer12-17-2018 23:32
12-17-2018 23:32
Fitbit support have come back to me to say they are aware of the problem and are looking into it. I suppose we just need to watch this space for now
Best Answer12-18-2018 13:39
12-18-2018 13:39
My stats are not showing anymore on my fitbit versa. I was able to do yesterday before I did the latest firmware update. Can someone help to fix this problem? Thank you!
Best Answer12-18-2018 13:43
12-18-2018 13:43
Hi everyone,
I'm experiencing the same issues. Everything was working fine yesterday.
Thanks for any suggestions
12-18-2018 16:30
12-18-2018 16:30
Hi all!
I had the same problem - I tried re-setting my versa multiple times, plugged it in to the charger overnight, shut down my phone and app to restart everything - nothing worked.
BUT I FIGURED IT OUT! If you have an iPhone and did the update on your versa, you also have to update the Fitbit app itself through the App Store. I updated the Fitbit app (update from 12/10) and it took a few minutes to fully update the ‘Today’ app within the Fitbit app, but once 'today’ installed fully in the Fitbit app (I had to manually start the installation) it was back!! It immediately showed back up in the app and on my versa. Woohoo!
Hope this helps!!!
Best Answer12-19-2018 00:04
12-19-2018 00:04
Thank you for your response. I updated the app and all now appears to be working again!
Best Answer12-19-2018 04:41
12-19-2018 04:41
Best Answer12-19-2018 08:15
12-19-2018 08:15
Hi! I’m not sure if it works for Android, I have an iPhone. It’s probably worth a try though! If you do try and it works, please let us know. 🙂
Best Answer12-19-2018 08:18
12-19-2018 08:18
Yay!!! I’m glad it worked!
12-19-2018 08:33
12-19-2018 08:33
Best Answer12-20-2018 01:20
12-20-2018 01:20
@Fat2Fit_1978 by stats on your Versa, do you mean they are not displayed:
- on the main versas screen aka clockface
- in the today app (swipe up on the main screen to access)?
Or perhaps, you share the common issue of not being able to open Today app on your Versa? If by any chase you meant stats on the clockface, it means your clockface needs an update as it is not compatible. Change the clockface to resolve this issue.
03-14-2019 09:48
03-14-2019 09:48
This drove me crazy.
I deleted versa from my app and 're added it. Worked
Best Answer10-07-2020 20:54
10-07-2020 20:54
Still not showing daily stats again. I’m tried of the game playing with it.
Best Answer06-10-2021 22:42
06-10-2021 22:42
This also happened to me I reset my Versa 3 and got everything back
Best Answer12-27-2022 01:13
12-27-2022 01:13
For Android all you have to do is go to the watch settings on actual watch and shut down. For versa 3 at least, I'm not sure the others. Nothing to do with phone.
