07-12-2018
04:22
08:32
AlejandraFitbit
07-12-2018
04:22
08:32
AlejandraFitbit
I've had my Versa for about a month now. I have been having tons of issue since then. Yesterday, it stopped reacting to touch. I cannot swipe and access to any apps or the setting. It still seems to be counting steps and recording sleep though. Anyone had similar issue?
Best Answer07-12-2018 07:35
07-12-2018 07:35
Do a Restart and do it several times if necessary.
Best Answer07-12-2018 13:30
07-12-2018 13:30
Mine started doing something similar a few days ago. I had mine about 2 months. It started with the screen randomly opening apps or shaking back and forth. I did a soft reset a few times (holding the left and right/bottom button), but that didn't really help. I tried a hard reset and then the screen completely died. I would recommend calling fitbit support. I spoke with Sam and she was very helpful and had me ship my fitbit back for them to look at. I haven't heard back yet, but I hope it is not a big issue.
07-13-2018 08:34
07-13-2018 08:34
Welcome to the Community @RTPB, @SunsetRunner and @Tracy1701D thanks for the input.
I am sorry to hear that your Versa touchscreen isn't working and would like to know if the instructions provided by our friends worked?
Hope to hear from you soon. ![]()
Best Answer07-13-2018 11:46
07-13-2018 11:46
I had similar after 2 weeks. I tried the various reset thoughts. No luck. I decided to return it while I could. Against my better judgement, I did get another in an attempt to try again. I wasn't going to having read all the issues. Sadly I just love the look of the Special, the purple n pink band! I plan to use it as it was intended and make sure it's gonna work right. If not, taking it back too and getting a Samsung instead.
Best Answer07-13-2018 14:04 - edited 07-13-2018 14:05
Thank all of you for the input. Unfortunately nothing worked. I wanted to call Fitbit customer service but could not find the number. I will probably email them and wait for their answer.
Best Answer07-13-2018 15:03
07-15-2018 06:49
07-15-2018 06:49
