When I track an exercise in my versa it shows up in the app as though I were tracking an exercise involving distance even if the exercise I've done is stationary. For example, I manually instructed my Versa that I was doing yoga. When i checked the app later for stats it showed up as
Yoga
0.15 mi --'--"pace
95 avg bmp
When I would perform the same function with my charge 2 it would display as
Yoga
1hr 2 min 152cals
91 avg bmp
Is there a way to have the versa display non-distance exercise stats the same way as the Charge 2 did?
Best AnswerI’m not sure what you mean? I can change the exercise type but I don’t know how to change the stats.
Best AnswerGo into your Fitbit app, click on you versa, scroll down to exercise shortcut, click the top right “+” and click on yoga. Now click on yoga and click on show cues. Click on auto and you can chose mins or calories. Not sure what happens when you chose manual.
Best AnswerThat did not work but thank you for your suggestion.
Best AnswerOh bummer...you couldn’t change out the different exercise shortcuts? Hmm, have you tried to start you Fitbit? Sorry, I couldn’t help you.
Best AnswerI can change the short cuts but it doesn’t fix the stats in the app. I don’t think restarting my device will make a difference because it’s the way the stats are displayed in the app, not an issue with them recording on the Versa.
