09-29-2018 13:28
09-29-2018 13:28
Best Answer09-29-2018 18:49
09-29-2018 18:49
Yes it will count stepsnin a wheelchair. The only way to avoid thi nis to put it in your pocket. It will also count steps while in a car, which is unfortunate, but it happens due to bumps in the road that the tracker interprets as footfall vibrations. The worse the road surface the more steps you will get. You can get rid of these false steps by logging a Driving Activity afterwards in the app (see below)
If it is counting steps while not being worn is on this is usually due to it being near a vibration sourse (for example a computer fan). Make sure it is on a firm surface to charge. If it is and it still picks up these steps then try restarting it several times and see if that stops it accumulating steps when charging.
Let us know how you go
DRIVING ACTIVITY
To log a driving activity go to your app, tap the exercise tile (running man), then the stopwatch icon in the top right corner. On the screen that comes up start to type in Driving and when the list drops down SELECT DRIVING from the list (very importand not to type in the whole word). Fill in the details and Log it.
Helen | Western Australia
Best Answer09-29-2018 18:59
09-29-2018 18:59
I understand the step tracking while in the wheelchair, I have never had a fitbit track steps while I am in a vehicle though. There is nothing near the Versa while it is charging. It has been on the table all day and it is now up to 3000 steps for the day. I have reset it multiple times but it has not changed anything. I even turned it completely off and back on with no change. I had it in my bag for 2 days while I was recovering from inpatient surgery and it counted steps for those two days as well. It doesn't seem to matter if I'm not wearing it or if I'm standing still, it keeps logging steps for some odd reason. I got this when it 1st came out and just now having these issues. There have even been a few times where it doesn't track my sleep while wearing it, but tracks sleep while it's on the charger.
