05-18-2018 07:21
05-18-2018 07:21
So i have a question,i had to return my versa yesterday as it was having to many issues with connecting to bluetooth not syncing.so my question is is the ionic the same as it runs the same software does the ionic have the same issues? ,as i liked my fitbit but could stand the issues it was having.I dont want to buy the ionic if its the same as the versa.
Best Answer05-18-2018 07:40 - edited 05-18-2018 07:41
@cath1971 wrote:So i have a question,i had to return my versa yesterday as it was having to many issues with connecting to bluetooth not syncing.so my question is is the ionic the same as it runs the same software does the ionic have the same issues? ,as i liked my fitbit but could stand the issues it was having.I dont want to buy the ionic if its the same as the versa.
They both use the same Operating System. Ionic has built-in GPS; the Versa uses "connected GPS" which means using your phone's GPS.
Best Answer05-18-2018 07:44
05-18-2018 07:44
hi thanks for your reply.
i was wondering though if the ionic has the same issues that the versa has with not syncing and other issues as it runs the same software as i dont want to buy the ionic if its no better then the versa.
Best Answer05-18-2018 07:54
05-18-2018 07:54
I don't have any problem with syncing or anything else with my Ionic but some people do. It depends a lot on your specific device that you use to sync. Look around the Ionic Forum and you can get an idea of what problems other owners are having. However, keep in mind that only people with troubles tend to post here. All those other folks keep silent.
