I've had the Versa for a few weeks now and Saturday it stopped syncing to my app for some reason. I've tried restarting the Fitbit multiple times and it finally re-synced once more (about 4 hours ago) but I've tried syncing/restarting at least 8 times since without success.
Any tips?
Thanks.
Best AnswerIt is on a Google Pixel 2XL.
The sync issue has been a little bit more consistent but it still doesn't work every time. I've also noticed that my Weather App doesn't pull data anymore and when I try installing apps or other clockfaces I get an "App Configuration Failed" error message.
Best AnswerUnfortunately that Pixel is not on the Supported devices list , which is probably why you are having inconsistant syncing and problems downloading clock faces etc. Do you have access to a supported device you could use for downloading purposes (like a friends phone, a tablet or laptop?)
Helen | Western Australia
I figured Pixel XL in the supported list meant both versions. Does it not?
It hasn't synced since Sunday now.
Thanks for all of the help!
Best AnswerDoing some more research it looks like the Pixel 2 XL really isn't supported. That's incredible and laughable.
Been a huge Fitbit supporter for years but this is beyond stupid. Had a lot of potential but guess I will return it.
Best AnswerYou say it hadn't ssnc since Sunday, was it syncing before Sunday?
I don't think on Sunday your phone read that it is not supposed to be able to sync. If a phone was syncing, even if Fitbit hasn't tested it, it should still be able to sync
Instead of copy pasting, I suggest this post to look at.
Please start at the 4th paragraph.
Appreciate the tip however that did not fix it.
Today was the last day to return it so I went ahead and did that. Will look elsewhere than Fitbit for now. Pretty ridiculous.
Thanks though for the help!
