04-29-2019
14:17
08:36
JuanJoFitbit
04-29-2019
14:17
08:36
JuanJoFitbit
Hi
I have just purchased my versa but I am having issues with my Jabra pulse headphones. I have paired my headphones with the versa but when I play music via deezer the songs will play for a second the stop for a second continuously.
The whole point of purchasing the versa was so when I run all I need to carry is my watch and headphones without the need of a mobile.
I have seen someone else post this before but Fitbit did not respond
Thanks in advance.
04-29-2019 14:38
04-29-2019 14:38
Hi, see this topic about pairing headphones to your Versa: https://community.fitbit.com/t5/Versa-Versa-Lite/What-Headphones-Work-With-Versa/m-p/2674217#M12452. Seethe solution, maybe this is helpful for you too.
04-30-2019 08:35
04-30-2019 08:35
@Tonywillow Welcome to our Fitbit Community! Regarding the issue that you are experiencing between your Versa and your Jabra headphones, I'd like to follow up and would like to know if the issue persists or if it got resolved after following the advice that shared @SunsetRunner.
If you found his post helpful, please accept it as a solution so other users that experience the same issue can find it easier.
Looking forward to your response! 😀
04-30-2019 09:45
04-30-2019 09:45
Hi
No @SunsetRunner advice did not resolve the issue. I already know the correct way to pair my headphones to my watch that is not the issue.
I have reset my watch and headphones several times.
I have also tested my watch with other speaker devices and my headphones with my mobile and I have no issues.
For some reason there is something just not working correctly with the connection between my Versa and Jabra headphones
Regards
Best Answer05-01-2019 06:48
05-01-2019 06:48
@Tonywillow Thank you for getting back! Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any doubts! ![]()
05-13-2020 00:21
05-13-2020 00:21
I am having the same issue? This was in 2019 so why has it not been resolved? Any tech people on here... sure all headphones should work in all devices... can fit bit please produce a list of headphones that don’t work with Fitbit so customers do not waste money :money_bag:....
