07-21-2022
07:07
12:23
07-21-2022
07:07
12:23
My versa wont charge, when I plug it in it says it is charging but it stay at the same percentage. And when I sync it won’t sync, same with try to update it.
Hi there, @FinneganO. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa. I understand where your concern is coming from.
I'd recommend following the troubleshooting steps provided in this help article Why isn't my Fitbit device's battery charging?
Hope that helps.
Best AnswerI had the same problem with my Versa2 not charging. I checked YouTube and found a couple of videos that helped. Suggestions provided included plugging the charger into a different outlet, changing the plug block, pressing and holding the button on the Versa2 until the Fitbit logo appears on the Versa2 screen and lastly taking a Q-tip dampened with isopropyl alcohol and cleaning the charging contacts on the back of the Versa2 as well as the contacts on the charger.
Once I completed all of the steps above, I plugged in the charger and snapped the phone in. My Versa2 started charging right away.
