11-27-2018 04:47
11-27-2018 04:47
Hi
I’m having an an issue with my versa only had it 3 months and battery is lasting just over 24 hours. I’ve read advice to stop using apps don’t sync as often?! What’s the use of having one I might as well just of bought a step counter for £10 instead of the £250 this cost! Disappointing.
Best Answer11-27-2018 05:31
11-27-2018 05:31
Have a look at THIS Help Article on improvomg Battery Life. If nothings helps then Id suggest you contact Support (link in my signature)
Helen | Western Australia
