08-13-2020
15:29
08:17
08-13-2020
15:29
08:17
My Versa is about 2 years old. Has been working fine with no problems. Then tonight I noticed the screen was black and wouldn’t respond to any of the buttons. Placed it on the charger and after a few seconds the diamond starting screen appeared and it vibrated. I then synced it and it showed 100% battery. Removed it from charger and it worked for about 20 seconds and then went unresponsive. After doing this several times I managed to get into watch settings and shut it down. Restarted it but it did the same thing. So I decided to do a factory reset. Whilst doing this I left it on the charger. This all seemed to work until I took it off the charger and the screen went black and all buttons were unresponsive again. I am at a complete loss as to what to try now. If anyone can help - please.
Hi there @Oleark53, welcome to the Community Forums. I'm sorry to hear about your Versa's recent behavior, I understand where your concern is coming from. Thanks for your efforts in troubleshooting your watch prior to posting here. Nice way to go!
Does your Versa vibrates when you connect it to the charger? If you haven't done so yet, I'd recommend the following suggestions:
If the suggestions don't work and your watch doesn't vibrate, please try the following steps:
