12-25-2018 07:55
12-25-2018 07:55
I just received the Fitbit Versa and everything set up well and I changed my clock face. Then about an hour later I went and tried to change my apps but they won’t show up on the app and the clock face won’t load on the app either. Everything else syncs perfectly except that. I can’t even look at the apps I have on the app, it just shows a blank screen. Help would be appreciated!
12-25-2018 08:01
12-25-2018 08:01
Mine is kinda doing the same thing. Just finished the setup and when I click clock faces to change it just spins and never loads. Everything else runs fine
Best Answer12-25-2018 08:02
12-25-2018 08:02
I'm having the same problem. Can't figure it out
12-25-2018 08:05
12-25-2018 08:05
Exact same issue! Just finished setting it up and everything works perfectly, but it will not load my clock faces or apps. It just spins forever when trying to load clock faces and with apps the screen just stays blank.
Best Answer12-25-2018 08:07
12-25-2018 08:07
I'm having the same issue! Please help!!
Best Answer12-25-2018 08:09
12-25-2018 08:09
I’m having the same problem. My apps won’t open they just spin like there trying to open.
Best Answer12-26-2018 04:11
12-26-2018 04:11
I ended up uninstalling the Fitbit app from my phone. Then installed it again. It made me set up my versa again also. But after all that it worked! I can see the apps and clock faces!
