08-16-2021
20:48
11:41
08-16-2021
20:48
11:41
Can't sync my Versa 2 with the app after a fabric settings reset. What can i do?
08-24-2021 11:43 - edited 02-24-2024 10:57
Hi there, @Yuly_gm. Welcome to the Community Forums.
As @SteveH has said, please note that the difficulties you're now having with your watch, usually happens when you've performed a factory reset without first unpairing the watch from your Fitbit account. With that being said, I'd recommend the following to solve the issue:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
08-17-2021 00:14
08-17-2021 00:14
If you have factory reset your fitbit you will need to go through the setup process again to reconnect it to your account.
In the app go into your profile settings by selecting your profile image on the top left of the main screen and then select "set up a device"
