07-20-2023
03:11
05:16
07-20-2023
03:11
05:16
Versa won't now sync with my phone (android) keeps asking to connect via Bluetooth and its not finding anything
07-20-2023 04:30
07-20-2023 04:30
Hi @Madalaine What usually works for me is to RESTART your Tracker. Then go to your phone's Bluetooth settings and unpair the Versa. Turn off Bluetooth and restart your phone. Then you ba k to your Bluetooth settings again and turn bluetooth back on (but don't try to pair the tracker). Then you to your Fitbit app and try syncing again. Good luck.
Helen | Western Australia
Best Answer07-20-2023 05:18
07-20-2023 05:18
Hi there, @Madalaine. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Versa.
I agree with @NellyG's tips and recommendations. Nevertheless, I'd recommend trying those steps in the following order:
With the steps above, what I want you to do is to pair your Versa first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer07-20-2023 11:35
07-20-2023 11:35
Best Answer07-21-2023 00:28
07-21-2023 00:28
Thanks, tried all of this. It just would find the bluetooth connection, even when i removed all other bluetooth connections. I reconnected my Charge HR and it found this no problem, so went to try and connect the versa, still wouldnt connect. I then done a factory rest on the Versa and now it wont even switch on. So back to using my Charge HR
