09-14-2018
12:59
04:44
AlejandraFitbit
09-14-2018
12:59
04:44
AlejandraFitbit
I turn off the Fitbit but the screen stays on and flickers sometimes. It's draining the battery.
04:46
17:18
09-16-2018
04:46
17:18
Welcome to the Community @Blackberry1996.
If your Versa display isn't working, I recommend restarting the watch by doing the following:
About the battery, take a look at this post and following the instructions provide there.
Let me know the outcome. ![]()
Best AnswerI am also having the exact same issue.
Best AnswerHi, I really hate to suggest this, but I'm afraid this will be the only solution: try a Factory Reset. In the link you will find how to do that and also that you need to setup your Versa as if it is a newly bought watch. Good luck.
Best AnswerThanks , after 3 or 4 attempts I was able to get the factory reset to complete. Bad news it may have been my favorite watch face that was causing the issue. They have removed it from the library 😭
Best AnswerYep, that can happen cause Third Party Clock Faces are not always completely compatible with the new Firmware Version.
I thought I had this issue resolved after several factory resets. However now my Fitbit flashes on and off every 10-20 seconds ? Doesn’t matter if I have it on my wrist or not ?
Best AnswerHi, are you able to do anything with your Versa? If yes, install a Clock Face from Fitbit itself. The default one is called "Layers".
Best AnswerI tried this and nothing is happening.
Best AnswerI had to do a factory reset to get the phone to shut off. Not a problem since I am still in the process of setting up my fitbit
Best AnswerI tried the whole hold for 10 seconds... i even tried holding it while charging and nothing its stuck on the last thing i did last night "source". its been this way for 8+ hours. Battery isn't draining which at this point i want it to die so i can see if the screen will change.
Will not restart, will not allow you to press anything on the screen!
Best AnswerHello my fitbit will not turn off i've tried everything holding the side it just wont do anything can someone help me figure out how 2 reset it
