08-06-2020
09:21
12:52
08-06-2020
09:21
12:52
My Fitbit won’t charge of even show that it is dead
08-07-2020 12:56 - edited 10-03-2023 10:13
Hi there @2023, welcome to the Community Forums. Thanks for letting me know that your Versa isn't turning on or charging, I'll be glad to help you to sort it out.
As a first approach, I'd recommend trying the following suggestions:
If the suggestions don't work and your watch doesn't vibrate when you connect it to the charger, it may not be having a good connection with the charger and therefore, it won't properly charge. Said that, I recommend doing the following:
Best Answer08-07-2020 12:56 - edited 10-03-2023 10:13
